Juggler Techie Answer Guy Donating Member Registered Jul 22, 2003 #1 Stock '03 Busa, and I'm thinking of going -1 up front. Do I have to mess with the chain at all (remove links, etc.)?
Big E Donating Member Registered Jul 22, 2003 #2 Yes. I did the mod to a chain with 10 k on it. Its almost stretched to its max
MET The Watcher Registered Jul 22, 2003 #3 1 up in front would be 18. I assume you mean down in front from 17?
Juggler Techie Answer Guy Donating Member Registered Jul 23, 2003 #4 (Ninja Eater @ July 22 2003 said: 1 up in front would be 18. I assume you mean down in front from 17? Click to expand... I actually wrote " -1 up front". I probably should have written "-1 on the front"
D dezzy7 Registered Jul 23, 2003 #5 I'm not sure but I believe going down on the front should give you slack on the chain. Going up stretches the chain.
