rusu.bogdan
Hi everyone. My first post here .
I have installed two front and back tail led turn signals in my 2006 busa. Recently I changed the entire set of fairings.
I clearly remember when I tested the lights in the end, everything worked well until the battery went off. I removed the battery for like 2 weeks (winter here in Canada). Today after adding the battery back and starting the busa, I am noticing two issues; the scorpio sri500 alarm is not longer functioning. In the same time when attempting to turn left or right flash signals, all 4 will be flashing in the same time instead (same as the hazard flashing lights)
What could have happened?
It seems that I have a led flasher relay as well the original one. I thought firstly that I might have inverted the wiring insight the fairing nose , left with right, but it still should have worked in a mixed way i guess. Could be one of the relay the problem here?
I unplugged as well the back lights believing it might be an electric short, have changed the fuse (ok) no change though..... :-(
