Mythos
Constant airflow might not be the key if there's a constant leak past the bead. ...although you might get it to work. Worth a trip to the station to try it. You'll hear it pop like a little fire cracker if it works and it will hold air obviously.We shall see about inflation. I do not think my tiny portable unit will work so I may have to transport the wheels to the gas station.
The real key is rapid air flow. a ball foot chuck with the valve removed and valve stem with core removed will let the air burst in so fast, it doesn't have time to escape the bead. I used a little pancake compressor and it did the trick along with those two other techniques.
Here's a little tutorial I whipped up. See the sixth picture down and the last picture at the end of the tutorial.
Tire Removal and Mount
ZX-14 Ninja Forums : ZX-14 Conference : ZX-14 HOW-TOs : Tire Removal and Mount
zx14ninjaforum.com
You got the hard part done. Seating the beads is really easy. ...at least with the valves taken out of the equation. The air will blow back out of the empty valve stem when you pull the cuck off. The beads are seated. You put the core back in, inflate the tire to the proper psi and then all you need to do is to put the wheels back on.
