how do i tell if my b king has abs
angry-bird
I hear if it has a sticker on the front fender but that could come of how else can i tell for sure.
sixpack577
Top Gun
The calipers have a wire going to each one.
The rotors also have an inner ring that is visibly different from regular stock Busa/B-King rotors.
Jeff Kurth
Banned
Just tell it to workout a little more and do plenty of sit-ups.... Dont put soo much gasss into it...
Busa1166
The reckless and death defying way to tell is take it to about 60 and and grab a fistfull of brake lever, if you are not flying over the handle bars doing a superman impersonation you sir have ABS
angry-bird
I looked for wire's and dident see any.I forgot about the teath on the rotor. That causes a magnatic pulse for the abs wheel sensor dont it. I will go check that also. I was told that if i want to be a hooligan on a b king make sure its not abs.
angry-bird
No teath and it looks the same as the busa. Before i grab a fist full of front brake i would just do a burnout. Lot safer.
dadofthree
Seasoned Beef
I was gonna suggest placing it on stands or a lift and checking out its belly :dunno:
GIXERHP
Now thats the balzey test for sure!
Karl_1052
ABS rotor(notice the ring of teeth on the inner portion of the rotor, and the sensor that counts the holes)
Non ABS
Dscahill
Shouldn't there be a dummy light for the abs on the gauge cluster?
-D
