Im in the process of putting my extended swingarm on the bike and figured that I might as well get the shock set up for the extra length and my weight. I have called a few of the shops and I am getting different info. Im planning on running the bike 5" over stock and Im right around 240lbs suited. Some say that I just need to revalve the shock and that the stock spring is enough. And others are telling me that I need to run a stiffer spring plus the stiffer valving. I would imagine that after adding 5 inches of length and my fat ass on it I would need a stiffer than stock spring, but then again what do i know:grind: So for those that are running an extended arm and weigh over 200 suited what did you do? and what kind of 60's are you pulling? Im hoping that with the added length and shock ill be able to pull some high 1.3x 60's I figure the stiffer spring will also help keep the tire off the tail light. Im trying to get the bike as long and low as possible without having to change the stock tail.
Im thinking of a stretch also. I think 8.99 is coming up..
