OB_Cisco San Jose
What I would do first is to check on the memory Ram onboard,check on the disk size for the Hard drive,check on the video card.Just do a check list of what is on board.
To run Win95/98 correctly you'll need 32megs ram and 64 would be great.
For Video it would be nice to get something that supports 2D/3D graphics with 8megs on board.
Check on the open slots to add boards,I'm sure yours would have ISA slots or EISA slots and would be better if it had PCI Slots.Check your hard drive and a 1.2 gig drive would work and if the machine came with 800meg hard drive that would be ok.Check your BIOS settings of the computer to make sure it will support the various hardware you install and this will also setup your clock and hard drive configurations.You can do format and system checks from the BIOS table also.Also check to make sure you have 3.5inch floppy drive onboard.Check your Hard drive controller to see if it will support your CDrom drive and Hard drive.The older 486 systems disk drive controllers would only support two Hard drives.IDE disk drive controllers are better.
Now what I would do is reformat your Hard drive by using Dos 6.0 or higher.You can find your format.exe on your DOS floppy and you should run Format/s on the C:drive this would put the system information on the boot partition and make you C:drive bootable.Make sure your 486 has a CDrom drive also makes it easy to install software and for the kids to run their games or CDs.If you don't have a sound card you might have to install one and their very cheap as low as $8.00,make sure all the hardware is in your system before you load Win95 or Win98 and you want to make sure that you use a full version load of Windows instead of the upgrade version makes it alot easier.Hope this helps out. Good Luck,Any problems e-mail me at CiscoJ@aol.com and I will try to help.
