Grr - broken speed sensor nut
maoz
The Hayabusa service manual was less than helpful on giving the proper instructions on how to remove the speed sensor nut that is attached to the engine sprocket shaft. Well I thought I had to use a wrench on the nut, and didn't notice the allen head bolt until too late. I broke off one of the four nubs on the speed sensor nut.
My question is - do I need to buy a new speed sensor nut or can I still use this one? I don't see the functionality of the nub I broke off but perhaps I am missing something. Thanks so much for any help, I want to get this taken care of ASAP.
Revlis
Re-Recycled, Busa-Less...
I would probably just buy a new one, it cannot be that expensive.
Sucks that the service manual didn't help...
Odyssey
Is it just me or does that thing look really cheapo
Revlis
It's not you Bro, It's something that really torques me about Suzuki...building to a price point is one thing, but I would have gladly paid another couple of grand for a bit more attention to detail and some better quality/materials.
maoz
It isn't more than $13 with shipping but I would like to ride this week (the part won't be here until late next week). I am almost positive it won't cause a problem riding as is. I'm not sure why it has the four nubs - on other areas of a motor vehicle it would have the four nub design to be used as a castle nut (i.e. so you could stick a cotter pin in the shaft to ensure the nut never comes loose). Any thoughts on this?
SierraFlyer
You might have vibrations from being out of balance if this thing spins. A small imbalance can cause a big problem at speed. Where is this thing mounted?
maoz
It is mounted on the drive shaft which the front sprocket is affixed to.  The part's technical name is:  Rotor Speed Sensor.  I am assuming that it merely helps the speed sensor gauge how fast you are going....  Does this sound plausible to you?
Curt
its no prob to ride with a broken tab on the speedo rotor, only problem is ur speedo will read 25% lower than usual.. this is the problem i had for my first year with the busa til i figured it out.
u can even ride without one, and have no speedo.
not sure if this affects the odometer, but without one and no milage adding to the bike would be nice :P
maoz
Curt - that is great information!
Thanks for your insight into this problem! Now if I can just get the front sprocket changed tonight I'll be good to ride. Thanks again!
Revlis
Hey Bro I think I have a good idea for you. To avoid any potential vibes or weirdness take a dremmel or whatever you have handy and cut off the opposite side of the one that broke off. Help keep things from getting bizzarre. Then to hell with your speed being accurate until the part shows up.
MikeUSF has been riding with no speedo for quite a while...No Tickets and hauls ass everywhere. It's like he is freakin blessed or something....
Just a thought though, trim up the opposite side and keep thing balanced.
BA BUSA
MotoGP Wannabe
It won't hurt anything to ride it that way but your speedo will read 25% low. If your doing 100 it will read 75.
maoz
The old lady kept me from working on the bike last night so tonight I hope to get the new sprocket on. Revlis - that is a good idea, just to balance everything out. I will do that tonight.
Thanks again guys!
buddha65281
I know this is an old thread but are all year speed rotors interchangeable? I am finding different part numbers for 1999, 2000 and then 2001-2007. Thanks
202mphbusa
View attachment 420570 My question is - do I need to buy a new speed sensor nut or can I still use this one? I don't see the functionality of the nub I broke off but perhaps I am missing something. Thanks so much for any help, I want to get this taken care of ASAP. View attachment 420571
So you have a excuse for speeding
It will read 3/4 speed
buddha65281
No excuse needed, bike says it all.. Btw, i bought this one in Kiel!
