well i just got done rebuilding my motor. its a stock 06 busa. was turbo'd until i detonated 2 pistons.... so i rebuilt it back to just stock. i replaced all main bearings, rod bearings, pistons, rings, and new cylinder. Didnt do anything to the head just cleaned the combustion chambers up. i know i have the timing right. popped the valve cover last night to double check. the motor has 13k miles on it. stock cams pretty much stock everything else but HD output shaft. also i welded the inner clutch piece today so see if that was it. NOPE i start it and it runs perfect for a bit then starts to surge from 1200 to about 1800 and while it surges it makes a ticking noise. im thinking maybe manual cam tensioner time???? any ideas ?? the bike runs smooth and no smoke or vibration. tried it moving in the driveway up to second and you could still here the ticking. any help would be greatly appreciated.
