(...) Not a huge deal,I did one years ago. I think they are in the 100 dolla range. Dont forget the cover gasket if you order an' indicator.
yes rubb right - and the entire work can be done with a small amount of tools.
but what you definitely need :
- kinda loctite (middle strong)
- pressed air ´n tool for the clutch´s nut
- two torque wrenches - 4-20 Nm and a big one, 50 - 200Nm for the nut (gen1 needs 95 Nm, gen2 needs 150 Nm , both plus locking the clutch sleeve hub nut with a center punch. )
the new cover gasket - better to have, yes!, but in 98% not necessary. my new one (from 2010) is still waiting to be used
the original is usually coated with graphite and don´t glue to the cover/trans box.
so if you screw carfully the gasket will "overlive" and can be used sveral times - my experiance.
the entire work needs some 1.5-2 hours from very 1st to very last screw (bike 100% completed) - my experiance by already 3 or 4 replacements.
