As usual I'm confused, but at the gas station I just leave the key in it and it usually stays open. If you're talking about keeping the tank up when doing maintenance; there's a rod in the trunk that does a good job. Hope that helps...........
I'm to lazy to pull mine out and usually use a rubber mallet between the neck and the tank. It's made from 1/4 rod ( my estimate ) but has several bends in it. ( Fuel Tank Prop Stay ) I'm not at home or I would take a pic of it. If you get one and use it, it goes in the whole in the center nut of the top clamp ( Steering Stem Head Nut ) and one of the bolt holes at the front of the tank. Best of luck.
thanks for the pics and info, appreciate it!
Im going to try and find a used one, otherwise looks pretty easy to just make one up at work.
thanks, problem solved!
I'm to lazy to pull mine out and usually use a rubber mallet between the neck and the tank. It's made from 1/4 rod ( my estimate ) but has several bends in it. I'm not at home or I would take a pic of it. If you get one and use it, it goes in the whole in the center nut of the top clamp and one of the bolt holes at the front of the tank. Best of luck.
