fuel pump
cerebusa
I have a 99, getting a c-41 code,pump was locked up.This is the 2nd time in a yr.My son dropped it this time and buggered the tail and fairing.Is there an aftermarket replacement?And yes I have done the inline filter thing,just need to know who has a new type pump that will work w/o changing tanks.Thanks Mike
nobody has any answers to thias prob.?
???help
okay due to you did not want to look it up........ I did for you and the code is for the fuel pump relay and guess where it is at?
the left tail.
but check the fuse first.
And yes you can do it with after market stuff but you would need a PC3 usb
Well now,I knew what the code refered to ,I also knew the pump was the problem before I checked ,because the fuse was blown.This is the 2nd time I have beat this dog.All Im asking for is where in free world can I get a pump,that will work on this bike,without changing the friggin tank,or using another crappy stock pump.Thank you
