3WheelerMod
I have a Gen 1 (2006) I have been going through some electrical issues (grounding problems) that I believe I have resolved.
When I turn the key gauges sweep but I don't hear the fuel pump cycle.....
1. No F1 codes
2. Fuel relay is good. (checked ohms from relay all the way to pump)
3. Tip-over sensor has been modded and the bike turns over ...
I seen a youtube on testing a GSX1000 using a volt test. Using the ground and one of the TWO wires going to the pump. Busa's have 4 wires... ( Ground, gas level, power, ??) - is what I am assuming
Anyone know how to test if the fuel pump is functioning with a volt meter?
Todd
1. No F1 codes
Todd
