binx
I have dunlop q2's and the front tire is cupping with less than 1000 miles. Has anyone had this issue or know why these do it ? I had one replaced last year under warranty with less than 2000 on it. I run 40-42lbs in the tires which I was told by dunlop is fine. I had the suspesion set to my weight after the front was replaced last year to see if that would help. It hasnt helped and was told by the shop when I called to find out if this was a problem, and was told that because the Busa is so heavy that even with the right pressures and suspension settings these are going to do it under braking. The balance is also true. Is there anything else I should look for ? Its nice to get a new tire under warranty but I am tired of doing 2 fronts to one rear which I got 5k out of. The bike does not pull to the side and the bearings are good and the brakes were just replaced. The bikes an 05 with 10k on the clock with the original oil in the forks, which is going to be changed soon. Ive checked everthing I can think of. I know you guys will know what it is.
