OB_hiabuser
Well folks, here is the fix for the cutout problem. (drum roll please) Crank Angle Sensor. simple huh. well, before everybody who's had it checked out tell's me that it isn't what's causing the problem, i will just say this. mine tested fine with the suzuki test's listed in the suzuki service manual. bench tested just perfect. on a hunch, my dealer's mechanic, who happens to be a really good friend and an excellent mechanic, went on a hunch and replaced the crank angle sensor (he had a crashed busa at the shop and borrowed it) and voila! it worked. no more problem. not to mention that i was losing hp by the droves toward the end. down to 90 rwhp just before we replaced it. now it's back up to over 160 rwhp and run's like a champ. so, when your dealer tell's you that the crank angle sensor is testing fine, you can opt to spend your own money to order one and prove them wrong, (if this is definately the same problem everyone else is experiencing.) then make them pay you back for it when it fixes the problem. hope this helps.
mike
mike
