jeremy78233
I just finished rebuilding my motor after melting two pistons (to much boost). Anyway I took it to a shop to degree my cam gears brought it home put in the bike this past weekend and tonight I was finishing up little things here and there, and while looking for a return fuel line I came across my cam chain guide. If you were looking at the cam gears straight on it would be the guide that goes on the right side its the one that easily comes out. As you can imagine I went through a mild panic attack, everything is together and back in the bike and I'm trying to find out if can just lower the front of the motor pull the valve cover take out the exhaust cam in insert the guide or am I gonna have to remove the head again (its studded) to get the guide back in. Also I installed a Cometic head gasket, since the bike hasn't been started yet can reinstall the same gasket or will have buy a new one again?
