I have a K6, that overheats. I have pressure from the coolant intake to the blocked but no pressure after the water pump. Everything gets pushed to the reservoir but the coolant isn’t boiling. Cap is in good condition but when it starts to overheat the cap starts to leak a little from the steam. Fan does not kick on at high temp idle either. I’ve flushed the coolant line 3 times and put a new thermostat in even though the original worked. If I squeeze the outlet line it pushes coolant out of the radiator cap. Any thoughts?
