Connecting hose for turbine lubrication?
Gixer
I have two questions.
Can I connect the wire for the lubrication of the turbine where it is connected chain tensioner or is it better to connect the main line (below the crankshaft)?
The first option is simpler to me, because I have an extra adapter for hose (from the chain tensioner):-), so I installed it on the left side of the machine, but I do not know whether it will negatively affect the quantity and pressure of oil that goes in the cylinder head?
What should be the diameter of the hose to lubricate the turbine (turbine has no ball bearings)!?
hope you understand my bad english :-)
Thanks a lot!
