So I am doing a 3,000 mile look see on my bike and checking the air filter and all that kinda stuff. Basically just playing and I find this hose not connected to anything. Page 1G-3 in the service manual refers to this hose as one of either the fuel tank drain hose or the fuel tank breather hose. In the attached schematic the unconnected hose is depicted in the inset window. I am attaching pics as well. In the inset window on schematic it shows the other hose as having the Y you see and one end tied off or not connected to anything and other hose connected to tank. On my bike as in pics both hoses from the Y on one hose connect to tank and the other as you see is just there.
This hose is one of the ones that are taped together with a heat wrap and hang down under your bike thru belly pan next to regulator.
Question is where does this thing go if anywhere ? I looked for almost an hour and as the two are taped together from the other end you cannot make it reach anywhere else. There are only two connections to the tank in this area that I can see and both are taken by other single hose with Y in it ?
Is this just another California extra that is there just in case bike is built for Cali ? The zip tie I put there just to hold it in place.
Please help and thank you in advance for it....
