I must first say I have not been very good about cleaning the front sprocket, chain and rear sprocket get cleaned all the time. On the way home from Laguna my chain started to make all sorts of noise and I thought something was going to break. I stopped several times but on the busa you have no way to lift the rear wheel when on the road.
So to save you the experince I had clean your front sprocket. Yes it's a little more difficult since you need to remove the sprocket cover and you may have to replace your clutch fuild, which is brake fuild DOT 4 or higher whatever you use for your brakes makes it easier. A mighty vac helps you greatly with bleeding it. Expect it to take at least one hour of your time.
I would suggest you do this often at least every 1000 to 1500 miles. I know I will from now on.
<!--EDIT|manatrader
Reason for Edit: None given...|1121704484 -->
<!--EDIT|manatrader
