Ive looked at the radiator and see that there's a large hose running from the bottom. Is that the hose I need to remove to drain the coolant? I also see a hose running off the bottom of the overflow bottle. Can I just remove the hose from the overflow bottle and let it run from there to flush both the bottle and the radiator? So far I've done tires,plugs,brakes.
Now that Ive taught myself how to work on my Busa and see that it doesn't take that long. Unless I absolutely have to take it to Suzuki I'll be doing all the work myself.. Just with the few things I've done in the past few days I've saved several hundred dollars..
