Blown Fuel Injection Fuse
tomdez
I went to start my 2000 Busa after a short ride. Bike turned over but would not start. The FI light started blinking, and FI appreared where the clock usually is. Towed to dealer. Dealer says blown fuse that feeds FI System was the cause. Said blown fuse caused by loose battery terminal connections. I suggested cleaning fuel injectors and FI filters. Dealer didnt feel that dirty filters of fuel injectors had anything to do with it. Has anyone ever heard of loose battery terminals blowing fuses? Any suggestions on what else may have caused the fuse to blow?
Kiwi Rider
The cause of a fuse to blow is excessive ( a surge) current flowing through the fuse as you may well know.
Usually a momentary short to ground in the circuit, or a dead short (continuous grounding usually caused by a bared wire touching a grounded object).
Dirty clogged filters do make the pump work hard and draw more current than usual, but my '99 Busa had this problem for years until I sorted it out, and it never blew a fuse so I doubt this is the cause as you were suggesting to the dealer.
If the battery terminal was loose, I think you would have noticed the bike switching off and on repeatedly giving a 'jerky' effect, or at least noticed something odd going on?
Is it running OK now?
Does it have full power?
Have you ever had the fuel system serviced?
How many miles on the clock?
If fuel system never serviced, would be a good idea to do it ASAP.
tomdez
It’s still at the dealer. They say it runs fine now. I have 35,000 miles. Never serviced fuel system. What does a fuel service consist of?
Kiwi Rider
1) Clean out the fuel tank and the gauze filter on the fuel tap.
2) Remove the external fuel pump, strip and replace fuel filter and clean out the pump housing sleeve and the small gauze filters in the housing.
https://www.hayabusa.org/forum/threads/1999-gen-1-fuel-pump-service.192363/
3) If you wanna go the full hog, remove the injectors and have them tested/checked (spray pattern) and cleaned by a FI specialist.
4) Fuel pressure and delivery test/ check
5) Fuel pressure regulator tested.
That's fairly comprehensive but if you do it yourself, it's inexpensive.
If you give it to a shop to do, go see your bank manager first!
jermzfree
Run premium through it you'll be fine :thumbsup: Plenty of detergents to keep everything clean. Your filter will eventually clog and need replaced. I noticed a big loss of power wide open throttle when my filter was on the way out, but no electrical issues.
Thread starter Similar threads Forum Replies Date
2fast4u2c "Flying Tiger" Blown Fuel Land Speed Racer Turbo 6
T blown fuel pump fuse issue Busa problems 2
6gear Blown fuel pump fuse Busa problems 6
Bigboy Busa2 Blown head gasket? Motor and Exhaust 7
Scotty_R8 Possible blown turbo? Busa problems 5
Kiwi Rider So the Whistle is Blown on the 'Climate Change' Scam at long last .... In the News 74
T Found The Source Of My Blown Head Gasket General Bike Related Topics 0
greg3852 Blown Coil Pack? General Bike Related Topics 15
little SOS...Traveling bike. Motor blown. Might need help in Rochester MN General Bike Related Topics 17
RYC1966 Blown out spider gears pics Random Thoughts 7
lankeeyankee blown fork seals and heavier springs? Gen II Busa Information 30
E DAS Performance Prostreet blown Busa Super Chargers 19
T Have you ever blown the cooling fan fuse? General Bike Related Topics 14
raydog I am blown away! Random Thoughts 17
Gavin Rogers Another blown headgasket? Busa problems 3
G Blown away by a School Bus Videos 6
rickneuhaus Blown head gasket All Motor 5
G WTB Blown busa motor General Bike Related Topics 7
kml blown piston w/ pics Random Thoughts 16
shean1 Blown head gasket Random Thoughts 11
H blown head gasket help Turbo 8
J blown head gasket Turbo 12
andy and the r man Blown Headlight Bulbs General Bike Related Topics 14
craigntx 250 hp blown v-max. for sale too General Bike Related Topics 7
bpjones Blown Fuse! General Bike Related Topics 9
Darth Z The Smurfs' villiage gets blown up.....SERIOUSLY!! Random Thoughts 18
MadLight Almost got blown away by a harley General Bike Related Topics 41
B 07 Busa Internally blown head gasket??? Please Help Busa problems 36
theskaz Blown 383 SBC Random Thoughts 11
busabad low beam headlight fuse blown Busa problems 0
ThrlSkr Blown Head Gasket General Bike Related Topics 64
thepushercg Blown to he## and back Turbo 12
P Blown Fork Seals General Bike Related Topics 8
Charlesbusa Lakers blown out by 39 points! Random Thoughts 10
H K8 Blown Engine from Wheelie? Gen II Busa Information 31
Mr Bogus Injection is Nice, But I Would Rather Be Blown Random Thoughts 16
69ls1 Blown Head Gasket? Turbo 6
J Blown engine? Nitrous 41
P Pics of my blown motor General Bike Related Topics 52
Jonny Hotnuts Anyone hear of water injection on non blown motor Engine and Performance mods 5
GMbusa Blown mini V8 Random Thoughts 14
steelhead Blown Fuse? Winter Riding Gear. General Bike Related Topics 8
V8N3T Hi Beam, light blown. Halogen replacement? General Bike Related Topics 6
turbojonn My blown up turbo. not for the squeemish! General Bike Related Topics 14
I Fork seals blown General Bike Related Topics 3
M Blown battery, fuse need help Busa problems 3
missilelike Blown Fork Seals!!!!! General Bike Related Topics 10
omslaw Blown Head Gasket!?!? Busa problems 9
E blown engine? shot brakes? General Bike Related Topics 12
Dr.Jekyll Blown Engine General Bike Related Topics 10
Similar threads
Latest Bikes
Forum statistics
Threads
174,592
Members
48,497
Latest member
fantomas
