2000 Hayabusa 20k miles. I got it about couple of months ago. It runs great overall. Engine has full power. The issue I started to have was it stalled at a light first. Then it refused to fire up after a long ride. I let the bike sit over night and it fired up the next day. I tried to diagnose it, I couldn't hear the fuel pump prime. I replaced the fuel pump relay with new. It starts right up now even after long rides. But I am still getting the stalling issue at idle and once in a while bogging when I go from 1st gear to second and I give it throttle it hesitates at first an then takes off. I noticed some rust in the tank, so I flushed the tank and used rust remover about 4 gallons and let it do its thing for couple of days. I was slushing it around every couple of hours. I also replaced the fuel pump with a brand new OEM Suzuki fuel pump. It fires up every time, but I it is still stalling at idle and bogging when i go from 1st to 2nd gear. I checked for codes by putting it in dealer mode and nothing there. I ran it in dealer mode and it stalled and no codes. the TPS is in dead center. Sometimes when it dies the tach and speedo doesn't work, I have disconnect the battery and reset it. I checked to see if the it was the charging system but seems to be charging and holding charge. I could take it in for load test if that could be a problem.
looking for advise on what could it be. I am going to replace spark plugs with NGK CR9E, also going to run some fuel injector cleaner in the tank. not sure if that will make any difference.
