Speedratchet76
(2002 Busa) The bike will only run if the vacuum line is off of the air pressure sensor. I replaced the sensor, but it still
acts the same way. It is the correct sensor and the sensor wiring passes the tests in the factory service manual. All vacuum hoses are good
and routed correctly. No codes ever come up in dealer mode. Thanks for any insight on this issue.
