I Truly Need Some Help; Please (hayabusa 2002)
Jeffrey8138
okay; i was having trouble with the bike (it wouldn't start up right away, and it would go ovr 150 mph); Took it to the shop they replaced the Spark Plugs, nothing changed ... then they replaced the Throttle Sensor because they said the READING was off, still no change... then they replaced the Throttle body it started Up , everything ALL GOOD... drive it FAR, and the ISSUES Returned it won't go Over 150, and it was Really Hard to Start ...
So, got TWO MORE Throttle Sensors, and Replaced the Throttle Bodies AGAIN. Started Right UP; YEAH ... then it CUT OFF, and by the Third try; would not start again.... THERE Are NO ERROR CODES
i am thinking Vacuum, or Gas being cut off from something else other than the Throttle Sensor ... Checked all the vacuum lines are connected, everything is connected (sensors, hoses, Airbox); anybody know why it just won't start (and yes Fuel Pump tested) ..... this is recurring; why
Jeffrey8138
No; though wouldn't that be something i would Need to Start the Bike for ... it won't start ... though i Took the Butterflies Off and Sprayed Starter Fluid through the AirBox and it Started and Ran at About 10,000 RPMs , i have Since Put The Butterflies BACK ON ... so i know; the engine works and the Plugs
Jeffrey8138
Had fuel pump tested; bought Throttle Body w/ injectors and installed them ..., it STARTED; then cut off (three times); then refused to Start Again
Mathewrussell52
I would still test fuel pressure. Could have collapsed line or a bad fpr unless everything has been tested . Have you put it in dealer mode? If your dumping fuel or starter fluid in it and it runs it's gotta be fuel.
David Offor
Yes, fuel pressure test needed, it's pump in tank on the 2002, there is a fine fuel filter in the housing next to the pump, in the tank, these become blocked and are stupid expensive from Suzuki, someone posted a mod, to bypass the filter (if that is your issue).
Are the plugs wet or dry, after cranking the bike? If they are wet (fuel), it could be that the injectors are being told to inject at the wrong time and missing the spark, this is controlled by the ckps (crankshaft position sensor), by adding carb cleaner, you are bypassing the ignition timing, that's why the bike fires up, if they are dry the injectors are not being activated, again the ckps tells the injectors when to operate.
Have you also eliminated the fuel pump relay, I've heard these play up and don't throw a code.
Jeffrey8138
Okay; i think i Know the reason... i emptied the Tank of All Gas , then added a Gallon of Hightest, then added the Entire 16oz bottle of Marvel Mystery ... IN MY DEFENSE: there's a Hidden Tear Off label with instructions (THERES NOTHING THAT STATED IT WAS THERE); so it should be One oz to every gallon... I put in 16
So, i'll empty tank again, and No Mystery Stuff Anymore
SSGT_B
I had a starting issue after I put mine back together from checking valves. Would be hard to start, run but poorly, and not re start. Mine was because I crossed 2 of the coil wires. Might not be your issue but worth a look when you get into it.
David Offor
I wish I could complain about 'not' being able to ride over 150mph, in the uk :lol:, it's either average speed cameras, bad road conditions or police speed traps, we would all be in jail :fire:
Screwy
Could be the fuel pump relay! Mine would cut out randomly but I have a fuel pressure gauge so could see the problem,try running a live of the battery to the pump live wire and see if that helps
Thread starter Similar threads Forum Replies Date
Sandow A truly powerful picture! Off Topic 20
RedBull Man Truly Has A Best Friend ~ And It Hurts When He's Gone . . . Random Thoughts 41
D The Hayabusa is truly a gem! First full day ride report General Bike Related Topics 10
TWT racer truly Amazing Random Thoughts 2
Takeuon This plane is truly an engineering marvel... Random Thoughts 16
Scar One Truly Amazing Toy Random Thoughts 11
raydog This is truly America General Bike Related Topics 16
raydog This is Truly America Random Thoughts 4
Takeuon Stunning work-Tinker's & Model Makers will truly appreciate this! (pics) Random Thoughts 22
HT_USMC Truly random thoughts... Random Thoughts 21
dadofthree Women are truly evil ii Random Thoughts 26
dadofthree Women are truly evil Random Thoughts 43
0 Is my Busa truly UGLY??! General Bike Related Topics 33
Ruben Only if you truly love her ..... Random Thoughts 17
RaiderDm TRULY PERFECT Random Thoughts 14
michael parris heuberger Hi. I need some clutch parts. Wanted 4
C I need help! (idle issue on my 04) Busa problems 15
rubbersidedown Mirrors/easy to see outa/you need lightweight/good looks/etc Appearance mods 32
shade Need bracket ideas General Bike Related Topics 12
shade Front fender bolts - need thread pitch and length General Bike Related Topics 4
rubbersidedown Rubb need hep Random Thoughts 13
gurrera You need a LOL today Random Thoughts 2
I i need an intank fuel pump!! General Bike Related Topics 11
J What all do I need to change to use a gen 1 swingarm on a gen 2? Gen II Busa Information 13
N Do I need Road 5 GT? compare to Road 5 General Bike Related Topics 24
M anyone good with led repairs..I have libertek diamond leds...need led repairing help Electrical Mods 1
B I need to ask u 1st gen vs 2nd gen exh header General Bike Related Topics 1
rubbersidedown Need help from my private investigators...Hayabuser,etc.... Random Thoughts 1
rubbersidedown I need help.LOL.Let me re-phrase. INFO NEEDED from a MOD/ADMIN/Member Random Thoughts 4
rubbersidedown photo program for windows 10? Free.Easy to use.web download.I need one. Random Thoughts 13
H Need help on tank hoses General Bike Related Topics 5
gurrera During these uncertain times, we need to smile Random Thoughts 1
rubbersidedown Heli bars,who needs 'em. I do.Or I need GIXXERHP I think General Bike Related Topics 2
B What will I need to get to 400hp? New Owners Forum 9
C Checked valve clearances today - need advice. Gen II Busa Information 31
kml Why you don't need to lower a bike to flat foot for control. General Bike Related Topics 2
M Engine in car. Need low fuel light. General Bike Related Topics 1
P In need of a shop relatively local Busa problems 10
SmokeKingOfCali99Hayabusa 2008 Gsxr 1000 Wont Start. Need Help !! General Bike Related Topics 17
S 2000 1397 need help pricing General Bike Related Topics 6
Mathewrussell52 Do I need to drop the motor to do head studs? General Bike Related Topics 25
L Need some help with my turn signal modification!!! Electrical Mods 3
Blacksmith Need new guages/faces... Gen II Busa Information 12
pashnit Need tail bolt spacers Busa Mods 2
M Port Richey FL area need work done General Bike Related Topics 4
B need help General Bike Related Topics 4
J Need hrlp fast i want to drive it to work Busa problems 1
E I need help with stretching Busa Mods 20
T What hydraulic clutch cylinder do i need for a lock up clutch on my 1300 hayabusa? (stock cylinder not strong enough.) Engine and Performance mods 3
U Why do I need to do my break in oil change at 300 miles for my 18 cbr1krr? General Bike Related Topics 7
Similar threads
Latest Bikes
Forum statistics
Threads
174,635
Members
48,513
Latest member
nightmare on elm
