whiteboy06
06 Busa 1900 miles, no mods.
here's the thing.
Bike kept shutting off at redlight,like it was running on 1 cyl.eventually wouldnt turn over.Could push start it and run about 2 miles and bike would act like its running on 1 cyl. again. but I had enough speed to roll start and run fine for a couple of miles and it start running crappy again. Made it to the motorcycle shop and the mechanic said the battery was the culprit,not enough juice to the plugs,replaced the battery picked it up drove it about 2 to 3 miles and same thing again running like crap.2 weeks go by and I heard nothing so I called, they said they found coolant in the crankcase and replaced a seal,but still there was coolant in the crankcase after flush and installed new part.Then he told me it was the water pump,so they replaced the water and seals and still there was coolant in the crankcase.Now I no nothing about motorcycles and this is my first one, but I do know turbo jap cars and I ask if they had checked the head gasket or checked for warped head or a cracked head.They keep putting off checking the head.And when I asked" would coolant in the oil make the bike run like crap that quick?" I got no straight answer.I know after time yes it would effect the motor, ie..bearrings and all parts needed for oil. He said they found no coolant in the cylinder, so they was no fear of hydro locking.So now I'm back to thinking it may be the head gasket but they keep checking for other things.Also they did do a compression test and the first reading was 198 psi but then leaked down 30% thats all he said didnt say which cyl.or if it was overall reading. So the question is?
1.What else is there to check?
2.what is the story with the battery,I thought the alt. supplied the needed power?
3.What else would give the power failure as described?
4.Why is this mechanic standing behind me with his hands on my shoulders?
OUCH!!! NEVERMIND I FIGURED OUT THE LAST QUESTION!
Any input,flaming,I told you so's,and name calling would be greatly needed.
Thanks Ladies and Gentlemen
Oh! and you, you know who you are!
Whiteboy06
here's the thing.
Whiteboy06
