clean
Hi guys, Just put my '08 back on the road. Noticed pretty quickly that "sometimes" it will fall flat on its face way too early. almost like hitting a rev limiter at around 9-10k. Oddly other times it will continue past 10k but not really making much power, and then sometimes it will pull hard all the way. no running issues otherwise - only at WOT.
right away I'm thinking fuel pump, but wanted to check if there's anything else I might be missing?
in early 2020 I did full maintenance on the bike including valve adjustment, air filter, plugs, new fuel strainer etc. So its not a clogged strainer as its brand new.
when I changed the strainer the old one was pretty dirty so I'm thinking the pump could have taken a poop kicking - also injectors could be dirty.
I was going to start with some seafoam, and if that doesn't help then do the pump. sound like a good plan? or is putting seafoam in these bikes a bad idea? I have heard mixed suggestions on sea foam - some say its can damage things.
anyway thanks for any and all suggestions.
