Hello,
For reference this bike is very new to me. Only had a couple weeks, I'll list engine related mods and symptoms.
2007 6700 miles (did not have a speedo healer w/ 16/42 gearing so it's actually less)
Muzzy full system 4-2-1
It may have Pair Valves blocked - it does not pop under decell.
BMC Filter w/ small Airbox mod
PC3 USB (mapping unknown @ the present time - haven't downloaded to view)
Cycle Tech Air shifter & shift light (currently not functioning/bottle empty. Lol)
I recently flushed coolant & changed oil as well as some minor repairs/cosmetic updates, unrelated to symptoms.
Symptoms:
at idle, approx 1100-950 would fluctuate mildly and occasionally hick-up. I bumped idle speed to 1200, is a lil better. As engine warms up it's more stable but the stumble is there.
Shift into 1st gear and engage clutch, start to accelerate the bike will drop a cylinder and sputter than pick up and go above 3500-4k rpm, does this in 2nd and 3rd occasionally. At cruising speed of 65+ I can feel an engine vibration around 4k. As I pull up to stop lights in Neutral, it will have an intermittent cylinder drop and pick up. It definitely a dead cylinder dropping.
Bike seems to pull well up to speed, nothing radical tho, So far I'm not very impressed. I also have a 94 GSXR1100 that's worked pretty good, so other than my 06 R1 & my recently sold 08 ZX10R, not much to compare it to.
My History, I own many bikes, this is my first Busa. I am a auto mechanic. I have a keen ear for symptoms like this. So, my question for you seasoned Hayabusa owners is, where do I look first?
The obvious diagnostic steps would be to #1: Pull Spark plugs #2 Compression test #3 inspect OHM Coils #4 check fuel injectors... I'm not aware of any common issue that may help alleviate some troubleshooting time. The FI has never come on, should I try and pull codes? Could the previous owner have pulled the FI bulb, so it doesn't illuminate (I've seen this with cars)?
With the current mileage and over all condition, I didn't expect any mechanical issues, so curious of any problematic or notorious component failures...
Thanks in advance & I look forward to a long stay here.
I've been a member on GDC for about 10 years.
- Cheers
Symptoms:
- Cheers
