hi i'm a new Busa owner, just bought bike, all original 04, seems fine except 5th &6th gear will rev out before shifting into gear, Abby ideas what this could be? Thanks for you're help.
I have only just purchased a 2011 busa and i appear to be having the same issue changing from 5 to 6 gear. The bike appears to hit a neutral then is difficult to shift into 6th. I assume this common with all busa's? Does synthetic oil help? I will have to try and drop the gear lever down i assume this is straight forward. Very frustrating
How many miles? I have heard that some busas have a break in period and it gets easier with more miles. A lot of the problem is people don't adjust the shift lever and get lazy shifting at the higher gears. I had this problem when I first got mine then adjusted and I make sure I shift firm and now no problems
