Stealth_Busa
I wanted to replace my clutch and brake fluids. The manual says only use Glycol Based Brake Fluid, DOT 4. Do not mix or use Silicon or Petroleum based fluids.
So here is the question. If I plan on replacing the fluid, what does it matter if I use a silicon based or even synthetic DOT 4 fluid? Are these fluids bad for the hoses, seals?
I am planning to replace the fluids by bleeding out the old fluid and replacing with the new fluid, until the new fluid starts to bleed out.
Any thoughts?
Stealth
Any thoughts?
Stealth
