From what I've read, DOT 5.1 is a silicone based fluid with a higher boiling point than DOT 4. If I recall correctly, silicone based brake fluids do not attract moisture. So, why not use the 5.1?
Also, my understanding is that to change the brake fluid, I should open the reservoir, then attach a vacuum pump and pull all the fluid into a container in between the two. After that, I should pour in new fluid, and pump the brake until no more bubbles appear, and then close the bleed valve. Is that about correct?
