joenub
so, i'be been after this sucker for over a month now, replacing everything that i can think of. the leak started to manifest itself with a simple drip off of the kickstand. so since i replaced the oil pan gasket already (when the clutch decided to disassemble itself on the way to work) i thought that it had to be it. right? wrong. finding now that it's been dripping from up higher around the shifter housing. pulled the water pump and shifter housing, waited four more days for more parts and replaced those seals. wrong again. while i was in there i found that the previous owner had apparently been cleaning the chain on a stand with it running (always a great idea, survival of the fittest). there was a big chunk of rag caught up at the clutch pushrod area masking it yet again. looks like this was a leaker for someone else and i'm thinking that they tried a quick fix. to me it looks like a caulk of some kind. has anyone seen anything like this before? im looking for pic of what the clutch rod seal is supposed to look like and any replacement tips that someone might have.
