You CAN make a slip on work.
You may need to fab a bracket for the muffler mount to the passenger peg, and the inside diameter of the header pipe and midpipe may be different. So you may need a reducer.
Depending on what you try to use will determine if it will bolt right on or require a little work, but it can be done.
As said above too, the header won't work.
