Look and make sure the dogs on your gears are not rounded off. Also look at the shift forks and make sure there is no wear marks on them, if they are bent you will not be able to see the bend you will only see wear marks on the forks. I would also send it off and have it undercut by someone such as APE, Fast by Gast, Schnitz, R&D, ect. that way you will not have anymore tranny problems.
