tire
lareguy
Wats the best tire ???bt56 only tuff 1500milles ,i use my 2003 busy every day (like a cruisser ) but i like to push hard ...but i dont want too put 10 tires a year ....Wats the best tire for me ....thank you
<span style='color:blue'></span>The Hayabusa absolutly eats Tires.  It's sort of a calling card.
I have heard some good things about Avon's new Sport Touring tire, <span style='color:blue'>AV45/46</span>
If you believe the hype they should offer a fair balance between grip and longevity.
Otherwise, you could sell the Busa and Buy a Nice pretty lil Vespa scooter, I hear you can get all kinds of tire wear on them...
You can also run a BT012 in the front with either a Bt10 or BT020 in the back. I've got the Bt012/BT010 combination and I really like it. I've got 2100 miles on the set and the rear tire hasn't squared off yet. I should get 4 to 5k miles which is about as good as you can get unless you really ride easy.
I'm not really sure how many miles I put on my Dunlop 208s but it was alot. I kept them from Jan 02 to Aug 02 on one set! I rode them down to the tread. Great dry and wet traction. Never a problem at all. I'm going to tell you they do take alittle getting use to them. When I first started using them I thought I was going to fall in the corners because they corner soooo much easier than the 207s I use to use. One thing that makes them last so long is there is alot of tread down the middle of the tire. I really don't know of a longer lasting tire. Good luck though! And choose well!
