SonicDeathMonkey
I just a 04 busa with an aftermarket tail section on it. The rear lights are led. The whole thing lights up when you apply brakes, but when you turn the turn signals on nothing. I took off the tail section and applied 12volts straight from a battery. The brake lights up like usual, when I apllied current to the turn signals they light up but do not blink (I assume so since I applied constant 12 volts to it.) The factory harness was not cut, the person before used taps to get the power to the leds. Any suggestions to correct this? Also, can anyone tell me which color wire does what? Thanks in advance for the help!
