Well while installing my new Galfer pads I got the brilliant idea to loosen the allen screws holding the halves of the caliper together. First rear brake job on a Busa but I thought it would give me a little extra room to get my C clamp in there to push the pistons in. Well to my surprise brake fluid started leaking - not much. About the size of a quarter. I immediately tightened the fuggers back up and proceeded to finish my brake job. I got the new pads installed and everything mounted. I pumped the lever - felt good. I checked the fluid level cold then after a 10 mile ride. Brakes work fine - no leaks - fluid level normal. Anyone think I screwed anything up? Should I leave it alone or is there something that should be done? Did I break a seal?
<!--EDIT|thismonsterlives
Reason for Edit: None given...|1156206470 -->
