hayabusaPuertoRico Registered Mar 31, 2007 #1 ANYBODY HAVE BOUGHT THE RAPTOR PERFORMANCE SHIFT LIGHT , IF ANYBODY DOES, WHAT YOU THINK ABOUT IT? IT'S A GOOD SHIFT LIGHT? http://www.raptorperformance.com/
0 05BusaLe Too much time to kill and money to spend Donating Member Registered Mar 31, 2007 #2 I got the black one with blue led's, it works great and it is small. Check with Charles at Street and Track.
Professor Hayabusa Immortal Staff member Administrator Registered Apr 1, 2007 #3 I also bought a black one with blue leds from Charles. Had it over a year. Works great!
hayabusaPuertoRico Registered Apr 6, 2007 #4 (05BusaLe @ Mar. 31 2007,15:48) I got the black one with blue led's, it works great and it is small. Check with Charles at Street and Track. Click to expand... Can you please explain to me how to install it. In which cable i have to tapped from tach?
BigBSBusa Comin' back stronger than ever! Donating Member Registered Apr 6, 2007 #5 I have the black w/ red LEDs.
0 05BusaLe Too much time to kill and money to spend Donating Member Registered Apr 6, 2007 #7 (hayabusaPuertoRico @ Apr. 06 2007,21:02) Ok but how i installed ? Click to expand... Switched power, Ground (both located on extra black plug behind headlight) and tach signal wire at rear of cluster. http://www.raptorperformance.com/Suzuki/hayabusa.htm
hayabusaPuertoRico Registered Apr 6, 2007 #8 (05BusaLe @ Apr. 06 2007,18:19) (hayabusaPuertoRico @ Apr. 06 2007,21:02) Ok but how i installed ? Click to expand... Switched power, Ground (both located on extra black plug behind headlight) and tach signal wire at rear of cluster. http://www.raptorperformance.com/Suzuki/hayabusa.htm Click to expand... Do you know thewire color for the tach signal? Thank you
