Raptor perf. dual mode shift light?
BiggDaddyBusa08
Anyone here have a Raptor Perf Dual Mode Shift Light on a GENII?
I recently purchased one and installed it according to the inst. I fired it up and the light comes on @ what the shift rpms are set at instaed of the launch rpms. I tried reversing the order in which the instructions tell you to program it and now the light does not come on at all. All connections have been checked and made sure I have tapped into the correct wires. It seems something is wrong with the way its programmed. Has anyone run into this and what did you do about it? The launch rpms is set @ 8,000/ cylinders set @ 4/ rpm limits @200 and shift is set @ 11,200. Because the shift rpms is over 9900 rpms I have to double the cylinder setting to 4 and the set shift rpms to 1/2 or 5,600 rpms. Any ideas on what the problem might be?
