airborneuph
Just finished my summer long project up, trying to fit Greg Smiths Race Tech dash and my AMS 1000 into a panel that fits neatly and reliably into the space of the existing Gen I Hayabusa dash .. Initially, after measuring things up against the dimensions of the stock dash, I wasn't convinced it would fit .. The AMS unit extends to either side of the display, and as a result, it's tight in there .. But it's finished, it's nicely done, uses the same mounting grommets and bolts as the stock dash, and it works perfectly . Took a bit of trimming of the stock fairing mount to clear the wire harness, but really very little .. No butchery involved . Electronics all snap together with plugs, both from the very nice adapters that Greg makes up, and from the wiring harness that I made for the AMS, so it's all easily removable, just unplug everything and the dash comes out with four bolts .. The original dash uses just two bolts on the bottom and tabs that press through rubber grommets at the top. On mine, I machined and threaded the aluminum tabs that are welded to the aluminum baseplate so they bolt in securely on the top as well as the bottom ..
If anyone is interested in making one of these for themselves, I'm more than willing to assist .. I can probably save you some time based on the mistakes and changes that I ran up against along the way .. I have a folder full of templates I can copy and email you if needed .. Plus
I have a couple of extra aluminum overlays which I'd be willing to part with at cost ..
Or, if you'd prefer to (plasma/arc) cut it yourself, here's a link to the (.dxf) file;
www.dropbox.com
