Competitors in Pro Stock Motorcycle have a choice of two drastically different powerplants, both of which are capable of 6.7-second performances at speeds approaching 200 mph. Here is a detailed look at both the Suzuki inline four-cylinder engine and the 45-degree pushrod V-Twin that powers the Harley-Davidson, Buell, and EBR entries.
Wow huh? 118 octane, 185-220 pounds dry, the V twins spinning over 10,000 rpm, 370-400 HP with the Suzys down 30 on HP and 80 pounds less torque @ 160, and an 1,850cc limit for the Suzy’s motor which is based on a GS 1150. Why not a Busa? That’s only 113 CI vs the V twin’s 160 CI motors. The Suzys (surprisingly) run two valve heads. Today some of them had the newer four valve heads and did well. Compression ratio @ 16:1 vs the V twins @ 14.5:1. Some of the differences are amazing. Imagine an 1,850 cc street bike running on 118 octane fuel that weighs only 200 pounds. Yeeeeahhhhh!
PRO STOCK MOTORCYCLE – V TWIN | PRO STOCK MOTORCYCLE – SUZUKI |
(left side of header image) | (right side of header image) |
ENGINE BLOCK | ENGINE BLOCK |
Design: Naturally aspirated 160-cid V-Twin, two-valves per cylinder | Design: Naturally-aspirated 1,850cc (113 cid) inline four cylinder, two-valves per cylinder based on an OE Suzuki GS 1150 |
Engine block: Billet 7075 aluminum, CNC machined | Cylinder sleeves: Ductile iron |
Bore: 5.125 inch (typical) | Bore: 89.5mm (3.52 inch) |
Stroke: 3.875 inch (typical) | Stroke: 73.4mm (2.89 inch) |
Maximum bore offset: 1.0 inches | Bore centers: 95mm 1, 2 - 3, 4 (3.74inch)/120mm 2, 3 (4.72 inch) |
Compression ratio: 14.5:1 | Compression ratio: 16:1 |
Bank angle: 60 degree | |
CRANKSHAFT | CRANKSHAFT |
Crankshaft: CNC-machined steel plain-rod bearings, roller mains | Crankshaft: CNC-machined steel nine-piece pressed/welded together with roller bearing rods and mains |
Rods: aluminum | Rods: high-strength steel |
Oiling system: Wet or dry sump permitted | Oiling system: wet sump |
Cylinder sleeves: Ductile iron | |
CYLINDER HEADS | CYLINDER HEAD |
Cylinder heads: 6013 Billet-aluminum, CNC ported | Cylinder heads: Cast aluminum, CNC ported |
Intake valve size: 2.70 inches | Intake valve size: 46-48mm (1.81 inch-1.89 inch) |
Exhaust valve size: 2.00 inches | Exhaust valve size: 38-40mm (1.49 inch-1.58 inch) |
Valve covers: billet magnesium | Valve covers: billet aluminum or cast magnesium |
Camshaft: Roller camshaft made from tool steel, four individual cams, gear driven | Camshaft: Roller chain driven, plain bearing, tool steel |
Typical lift: 0.575-0.625 inch (x rocker ratio) | Typical lift: 16mm-18mm (.63 inch-.70 inch) |
Rocker arm ratio: 1.8 to 2.0 | Lobe separation: 114-116 degrees |
Lobe separation: 110-116 degrees | Duration: 265-275 degrees (intake); 265-275 degrees (exhaust) |
Duration: 285-290 degrees (intake); 300-305 degrees (exhaust) | Lifter tappet: steel, DLC coated |
Pushrods: 8-inch length, minimum per valve | Valve springs: Steel, 195 pounds installed, 475 pounds max lift |
Valve springs: Steel, 500-pounds installed, 1,400-pounds, max lift | |
INTAKE AND IGNITION | INDUCTION and IGNITON |
Throttle body: Individual per cylinder/ billet aluminum with 3.25-inch blade | Throttle body: Individual per cylinder sealed to a common plenum airbox; Lectron carburetors also an option and widely used |
Intake runners: Billet magnesium or billet-aluminum, common plenum, breathing from sealed airbox | Fuel Injectors: Limited to one per cylinder |
Fuel Injectors: Limited to one per cylinder | Ignition system: electronic fuel injection/ignition, two spark plugs per cylinder. |
Ignition system: Electronic fuel injection/two spark plugs per cylinder | Spark plugs: Denso Iridium |
OTHER SPECS | OTHER SPECS |
Fuel: Sunoco SR-18, 118-octane leaded (mandatory) | Fuel: Sunoco SR-18 118-octane leaded race gas (mandatory) |
Fuel burned per run: 20-ounces, burnout to completion | Fuel burned per run: 20-ounces, burnout to run completion |
Spark plugs: Denso Iridium | Headers: Stepped from 1.875 inch outside diameter to 2.25 inch four-into-one collector |
Headers: stepped from 2.25 inch outside diameter to 3 inch | Engine scavenge: 20-22 inHG |
Engine scavenge: 20-22 inHG | Engine redline: 14,000 |
Engine redline: 10,400 rpm | Estimated horsepower and torque: 370 @13,600 rpm / 160 @ 10,000 rpm |
Estimated horsepower and torque: 400 @ 9800/240 @ 7,000 | Estimated weight: 185-pounds dry weight (engine and transmission as singular unit) |
Estimated weight: 220-pounds (dry weight) |
