damit i'm looking for the same map no one want to help why?
i see other boards with diferent bikes sharing maps why not here?i know someone have the map after i save 250 and come back from dino i will share damit
Sorry no luck findin the map you need. I would try the one for the stock air filter for now and maybe even one for another type of slip on exhaust with aftermarket air filter.
Call Dynojet, they will recommend which of there maps will be close enough to work.
The K&N filter doesn't change anything over the stock; other then you can clean it.
