positive ignition output wire?
ham4864
i have this alarm that i hooked up(not a scorpion)it has a starter disable it saws to hook the wire to the positive ignition wire output.O and yes i am searching as you read this.Its not a bad alarm at all the sensitivity is awesome and its loud as hell.Plus i got it for free.:thumbsup:
BlueHaya
I'm outta here!!!!
the starter disable is a touchy item. There has been debates on cutting fuel or fire. There is also the thought of the bike shutting off on you for no reason.
Just something to think about.
Do you need to know which/where the ignition wire is?
ham4864
yea guess your right Bluehaya.I have a garage,roadlok and an alarm i should be good you think.
BlueHaya
I'm outta here!!!!
thats what I have as well:beerchug:
ICEMANN
you can always use a relay to convert your negitave into a positve output and connect that to your kill. Should work just fine. Ive done foreign cars that way. Especially with the "door" locks.
jd
