Here's the issue.... the bike will be operating just fine.
Once it get's near the mid point on the temp gauge, it sky-rockets (50/50 mix of coolant and water).
The fan comes on, but it struggles to keep it out of the red.
If I am moving, it is not an issue.
If I am in traffic... it gets real hot.
I since wired the fan to a toggle and have been being proactive, but it is treating the symptom, vice truly identifying the root cause.
I put an IR temp gun on the radiator when it was running hot.
The top area was 190, and the bottom was only 130 degrees.
I validated that the water pump was functioning... it was cherry... looked like brand new.
I replaced the thermostat... no impact.
I also did the burping thing a couple of times.
Thinking there's a blockage, possibly some pinched areas not allowing the water to flow.
The existing radiator looks questionable.
The fender previously would make contact when it was strapped.
I have since trimmed the fender, but the damage has already been done.
Any ideas?
Do you think this is likely a radiator issue?
Thanks again guys.
Any ideas?
Thanks again guys.
