Greetings all,
I am in need of some assistance. I own a 2001 Hayabusa and recently did an engine swap on it. The replacement engine is out of an 04 with 13k on it and the PAIR system deleted. I have everything but the wheels and fairings back on it and went to test fire it. I can he the bike to turn over, and even fire but it won't stay running. I have to hold the throttle open which made it "idle" at 10k RPM. There is also a horrible backfire (really loud and consistent) when it is running. I swapped out the cam position sensor, the spark plugs and verified that all of the coil packs are delivering power to the plugs. I checked the inside of the tank, and its clean, no rust. I dumped nearly 5 gallons of fuel out of the tank and replaced it with HEAT and 93 octane still no difference. The only thing I have not done is manually clean the injectors.
Also I would like to note that aside from the backfire and stalling, the engine does not sound like it is misfiring. I am at a loss with what could be the issue. What am I missing? Thank you n advance for your responses.
