HI!
I bought an alarm with remote start by SteelMate. The problem I ran into wile installing was to find out wire called flameout. Alarm is functional but cant get the remote start to work without knowing what flameout wire is. I went through lot of threads and figure out that I need to cut orange/white wire that comes out of ignition but that doesn’t work either. When connected to that orange/white wire I am able to remote start it when the key is on but can’t get it to work when it’s off. All it does is starter kicks in but wont start. I also found a thread that mentioned about not cutting the orange/white wire by the ignition key and instead cutting black/white wire next to rear break fluid level indicator but same thing. Please help….
<!--EDIT|Shilpan
Reason for Edit: None given...|1155488811 -->
<!--EDIT|Shilpan
