I want to be able to run my fan manually with key on or off on my 2002 Busa.
Many people here have write ups on how to add an overide switch but I think they can only turn fan on with key in the on position. I want to be able to run my fan while the bike is off.
Here are my thougths:
Battery > Inline fuse > Swith (Double pole, single throw)> Fan
I think I would need a Double pole, single throw because from what I've read, the fan comes on when a ground is acheived by a relay. So I'm guessing I would be safe with DPST switch?
Can I just jump into the fan wiring right at the fan with this setup and not cause any issues with relay or temp sensor functioning? I would rather keep relay and sensor operational in case I'm foolish enough to let anyone else ride my bike or forget to turn fan on myself.
Also, thoughts on wire guage and fuse size for two fans with this setup. Thanks for any info
