hezekiahmunson
Hi, I have a 2005 Hayabusa with a Hahn turbo setup on it. It ran great other than leaking pressure into the coolant last year, ran 152mph 1/4 on 6 psi. To fix that I replaced the head gasket and also installed a base spacer while doing it. I installed the cams back in standard, so about 3 degrees retarded I guess with the spacer in.
The problem is I got it all back together and it takes about 10% throttle to get it to start and keep it running, and it surges back and forth very rhythmically about 200rpm. The AFR looks good around 16:1 low down, fuel pressure looks good around 40psi. Doesnt want to rev up. I disconnected the Power Commander and still same problem. I checked for vacuum leaks and dont see anything, no sensors unhooked. It runs smoothly other than the surging back and forth, no missing, I disconnected a plug wire and it instantly got choppy and missing, so seems to being firing correctly and smoothly.
Could this be result of the cams being put in completely wrong, or does it sound more like a bad sensor somewhere? I checked and double checked the cams, I put them back in exactly the same way as they came out, marked them and didnt turn the engine, but I didnt degree them.
Any ideas would be greatly appreciated! Thanks!
