As I am putting a new harness in my sand rail, figured this might be useful for others, I have seen so many problems with car installs of hayabusa engines with the electrical harness butt spliced to heck without the proper resistors installed to prevent codes from coming on.
Sidestand eliminator
Tipover sensor eliminator
Fuel pump sending unit eliminator (no code on dash) with fuel pump wires extended that use factory relay
Ignition switch eliminator (no code on dash) 12V and ignition On wires extneded
Left hand control eliminator, clutch wires extended (hook these to a momentary switch for starting), horn wires extended to use the factory horn
Right hand control eliminator, run switch always on now, and starter 12V wire extneded.
Hayabusa Car-Kit Install Package
If you are looking to install a Hayabusa engine in your sand rail, quad, etc., this would be for you. I have sorted out the elimination of stuff not needed with factory connectors, simply pick up a used functioning harness and plug everything in. Sidestand eliminator Tipover sensor eliminator...
boostbysmith.com
