2000 Hayabusa wiring harness problems
KHobbs
I have a 2000 Hayabusa I had you switch wiring harnesses I ordered one online and the one I ordered it does not have a plug for my fuel pump how do I wire the fuel pump plug in
atlbusa
Should be a plug with a yellow/red and a Black/white wire, that is the plug / wires you would need. Are you sure you have a 2000 harness? They are different than 01-07, not a direct drop in as you can see.
atlbusa
Look Here check the color of wires in the ECU connectors in the positions 17 and 35 If your orange wire is in 17 and black in 35 you have a newer harness. If black is in 17 and orange is in 35 then you have a 99/00 of course you probably bought an ebay "99-07" harness and it was really a "01-07" Harness. It is not hard to update to the 02-07 ECU. Of course if your running a power commander now, it will not work on the new harness.
16 bit ECU to 32 bit Conversion How to | Maintenance and Do-It-Yourself
Thread starter Similar threads Forum Replies Date
M 2000 hayabusa fuel pump Busa problems 5
P 2000 suzuki hayabusa Gsx1300R Turbo Showcase Forums 2
S 2000 Hayabusa fuel problem Busa problems 2
mrbush803 2000 Hayabusa won't start Busa problems 7
C 2000 Hayabusa Repair Manual Maintenance and Do-It-Yourself 0
tinmann840 2000 Hayabusa Won't Start Without Starter Fluid General Bike Related Topics 6
Kurtis Pardew 2000 Hayabusa Regulator Rectifier General Bike Related Topics 0
David Offor Hayabusa Gen 1 2000, 2 & 3 Cylinders Not Firing, Losing Coolant, Original Problem Is Back. Busa problems 28
DUNK 2000 Suzuki Hayabusa....charging Problem General Bike Related Topics 0
Chato_00 2000 Hayabusa Cluster Busa problems 5
EchoBase Looking For A Member With A 1999 Or 2000 Hayabusa Engine and Performance mods 2
Kevin Sakamoto 2000 Hayabusa Running Problems... Busa problems 8
tinmann840 Will 2002 Hayabusa Exhaust Headers Fit On A 2000 Busa? General Bike Related Topics 3
David Offor 2000 Hayabusa Only Running On 3 & 4 Cylinders. Busa problems 57
David Offor Hayabusa 2000 Ry, Fouling Plugs, Running Very Rough And Rich. Busa problems 13
T 2000 Hayabusa Shut off While Riding Busa problems 4
David Offor 2000 Hayabusa still over fueling, HELP!!! Please :) Busa problems 2
David Offor 2000 Hayabusa overfueling???? Busa problems 12
David Offor 2000 ry hayabusa only running on 2 cyilinders and rattle after headgasket rebuild Busa problems 5
G 2000 Hayabusa ecu and rotor upgrade question Engine and Performance mods 3
swerve1 Suzuki 2000 GSX1300R Hayabusa Crankshaft Needed Modifications & Aftermarket Equipment 4
R 13 years late. My brand new 2000 hayabusa New Owners Forum 7
S 2000 hayabusa fuel pump up grade Busa problems 0
K 2000 Hayabusa Issue Busa problems 12
H Hayabusa 2000 stuttering in low revs Busa problems 19
hayabusapower 2005 cluster on 2000 hayabusa info? General Bike Related Topics 5
Macfast Starter Clutch Question For 2000 Hayabusa General Bike Related Topics 0
hayabusapower 2005 Cluster on 2000 hayabusa General Bike Related Topics 1
B 2002 throttle body to a 2000 hayabusa Maintenance and Do-It-Yourself 2
pan Hayabusa trackbike victory - Shaun Giles, 2000 General Bike Related Topics 28
Pantera_RO 2000 Hayabusa problems. Busa problems 14
S Problem with 2000 turbo hayabusa !!!! Busa problems 7
B 2000 hayabusa has been sitting about 4.5 years General Bike Related Topics 47
A 2000 Hayabusa fuel system routing Engine and Performance mods 6
D 2000 hayabusa suspension set-up General Bike Related Topics 3
N hayabusa 2000 stops when hot Busa problems 12
E 2000 Hayabusa Stalling at High RPM’s General Bike Related Topics 24
N 2000 Hayabusa Question New Owners Forum 7
GoldenChild 1999-2000 Hayabusa pc3usb Engine and Performance mods 7
blackbusa01 Power Commander 3 map for muzzy BMC 2000 hayabusa Engine and Performance mods 4
blackbusa01 Power Commander 3 map for muzzy BMC 2000 hayabusa General Bike Related Topics 3
C 2000 Hayabusa Tank General Bike Related Topics 3
C 2000 Turbo Hayabusa for stunnah and others Turbo 2
B Stock ZX-10R vs Piped 2000 Hayabusa General Bike Related Topics 13
C 2000 Hayabusa General Bike Related Topics 9
jimg EMS choice for a 2000 Hayabusa New Owners Forum 2
jimg 2000 Hayabusa Power Commander II New Owners Forum 2
G 2000 blue Hayabusa GSX1300R in Fire Red General Discussion 2
O 2000 Hayabusa Horsepower Output General Discussion 10
Gixx1300R Hayabusa wins 2000 Design and Engineering award General Discussion 0
Similar threads
Latest Bikes
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
Forum statistics
Threads
174,202
Members
48,300
Latest member
NorthernViking
