Bike was starting up and running before I took fuel pump out and cleaned filter put every thing back together wouldn't start up for nothing but when I sprayed carb spray in airbox started up for sec then when I unplugged map sensor vaccume it would run longer if I plugged vacume back up it shut down I took pump out tested pressure and it was 70psi any answers out ther
